Message |
Especially since you were leaning the motor. Check behind the crank sprocket (remove the crank pulley, be careful) However, since this is a new purchase, triple inspect the oil pan RTV and the rubber gaskets at both ends of the pan. (Handtighten, watch the mating surfaces.) Take a camera and record the bearing numbers. Do the front main seal along with your 120k maintenance now if you don't know the hx of the motor. (Which in that case, I would replace the oil pump preemptively, check the bearings, etc.) Up to your level of OCD/worry.
NYZC
